Ir para o conteúdo principal
How to flash format
How to flash format demo unit
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
So fair warning before I continue these phones do not operate with a sim so you will not be able to use cellular. If you are hoping that formatting it will give you a fully functioning phone then you’re gonna have a bad time. Also the demo software can sometimes be hard coded in the phone and you may need to find a way of force removing that (it can depend on where the demo was from ). That being said here is an awesome walkthrough for that you may need to format the phone.
  1. Ensure the device is powered off.
  2. Press and hold the Volume Up + Bixby + Power buttons at the same time. Release all buttons when the Phone vibrates.
  3. From the Android Recovery screen, select Wipedata/factory reset.
  4. Select Yes.
  5. Select Reboot system now.
Esta resposta foi útil?
Pontuação 0
1 comentário:
hello and thanks for the info upfront.
but whan i try that it wil not go to the android recovery screen with the combo bibxy vol up and power buttons at the same time. how can i still do the wipe data factoryt reset?
por
Adicionar a sua resposta
Faisal será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 31
Ao todo: 1,748
