Ir para o conteúdo principal
Samsung's flagship phone, the Galaxy S8. Released in April 2017.
No Network Connection even with a good sim
The phone says “No network connection”. And it has a little circle with a line through it where it would usually show signal strength. It wont make any calls either. I just put a brand new screen,frame,back glass and battery in it. Not sure if it makes a difference though. Any help would be appreciated as I am planning on selling my s9 soon to get the s10. Thanks! (I have already tried the SIM in another phone. It works fine.)
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Hi Ethan,
Make sure that all your antenna cables are properly plugged in and intact.
Samsung Galaxy S8 Motherboard Replacement
Esta resposta foi útil?
Pontuação 1
2 comentários:
I did. I just took it apart and they are all good
por
I ended up just removing the board completely again. After reassembly it worked for some reason
por
Iam not an expert, but do check if IMEI number is there in settings. If not it will not recognize any sim card.
Pontuação 0
Adicionar a sua resposta
Ethan Leroux será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 18
Ao todo: 2,151
