After boot logo: www.apple.com/support?
Right after apple boot appears, screen shows a dead ipod cartoon with this website beneath it (www.apple.com/support). And suddenly ipod goes off. What can I do?.
Esta é uma boa pergunta?
Go into Diagnostic Menu by holding the center button and the menu button until the screen goes black, then hold down the center button and the back button. You should get to the diagnostic menu where you can run the internal tests. This should give you the opportunity to find out what is going on with the ipod Here is a video explaining it to you. MY first gut reaction is to say that it probably is your battery....Let us know what your diagnostics tell you. Of course, also try what Richdave is suggesting since it gives you a chance to see if you can access the ipod from your computer. Good Luck
Esta resposta foi útil?
Try forcing the iPod into Disk Mode
If that is not possible then you probably have a hardware fault.
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 3,232
1 comentário
does your ipod charge properly? Is it being recognized under itunes? Did anything happen to it?
por oldturkey03
