Ir para o conteúdo principal
O Pixel XL de 2ª geração do Google possui um display P-OLED de 6 polegadas com cantos arredondados. Disponível em configurações de armazenamento de 64 GB e 128 GB, e em duas cores: Just Black e Black & White. Lançado em 19 de outubro de 2017.
Pixel 2XL display dying pixels.
I’ve had this new screen and digitizer applied to my Pixel 2 XL and not white lines are covering the right side of the screen completely. [See Images] Any suggestions on a fix?
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 2
12 comentários
Is there any water damage to your phone? If not, please request a new screen as this seems like nothing but a broken part.
por
I don't know, it's hasn't been near water recently but that can be a cause?
por
where can i get new display for my pixel 2 xl
por
Please was the lines there before you changed the screen, because the lines just appeared in my 2xl while I was watching videos. Please I need a solution
por
@itua was the phone overheating?
por
Exibir mais 7 comentários
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
How long since the screen and digitizer were replaced?
If not long ago (<30 days) and it was done by a reputable repair service, take it back and show them the problem. They should provide some sort of guarantee on their work.
It may be a faulty screen which is not their fault but they should still repair it again. They would want to know about it if they were getting faulty parts from their supplier.
If you did the repair yourself (or it was done by a friend), contact the supplier of the parts and ask them about getting a replacement screen and digitizer.
Esta resposta foi útil?
Pontuação 2
2 comentários:
It wasn't repaired by a service I did it myself at home and I made sure to be extra careful during install. I purchased it with the tool kit for fixing phones that ifixit has and I used a heat gun that I have at home. So you're saying since I did it myself I should contact ifixit and issue an RMA to get a replacement?
por
Hi @lunaluvli ,
If you purchased the screen from ifixit, contact them about the problem
https://help.ifixit.com/article/49-retur...
por
Adicionar a sua resposta
Rose Watson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 10
Ao todo: 1,756
