Ir para o conteúdo principal
Guias de reparo para freios a disco, freios a tambor e sistemas de frenagem de carros e caminhões.
Getting two different size dimensions front rotors
Ok I went to VIP to get my front rotors and brakes for my 2016 Chevy Impala ltz limited .Now in there computer going by my exact make and model year so on. They kept bringing out rotors that I jus new were to big and nobody could understand why and they tried different brands of rotors and so on with the same result they were to big at this point me and the employees were clueless to why this was happening . So then we decided to put in my vehicle Vin number instead . And sure enough they went to grab that rotor and it turned out to be a smaller dimension. Does anyone have any idea why this would happen . I Kno sometimes they make mistakes but we went over everything top to bottom together on the computer and everything was correct as far as putting in my vehicle info . But the VIN number clearly did something different to get a different size pulled up when putting in all the correct information on my car was coming up with bigger size . If anyone has any answers to this would be very helpful myself and VIP both was at a loss of words with no explanation.
Thanks very much if you could shed any light on the matter !!!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
tiaracarson2012  sometimes car makers change things during further developments etc. There’s really no good explanation other than this will be decided by whoever designs/builds your vehicle. The VIN number will included those changes etc. and it shows the importance to go by that number vs. what your aftermarket catalog shows.
Esta resposta foi útil?
Pontuação 3
1 comentário:
I had a similar issue with a 2009 ford escape . The ford dealer explained it as the part was replaced as it came to the end of the year run . The part was upgraded in the next years model run and they didnt want to order old parts that may not get used up before the year model run was complete so they started the upgrade on that year and then carried on into the next
por Compartilhar
Adicionar a sua resposta
tiaracarson2012 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 41
Ao todo: 2,166
