Ir para o conteúdo principal
Laptop Gateway com 4 GB de RAM e 500 GB de HDD. Número do modelo: NE56R49u.
I cannot type numbers
Hello i tried typing numbers, yet its not working,, rather only symbols are working.
I used the set of numbers at the right too yet they didn't work.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @odimexy ,
Are all the letters OK or are they showing in upper case (capital letters) only?
If they are in upper case (capitals) only check if there is a Shift key stuck in the operated position as this will affect the numbers above the letters on the keyboard as well.
Have you checked that the Number Lock light is operated on the keyboard?
If not press and release the Number Lock key (the number lock light should come on) and then try the numbers on the keypad.
has any liquid been spilled onto the keyboard at all?
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Odidi Junior será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 23
Ao todo: 954
