Ir para o conteúdo principal
Processador de 1,4 GHz ou 1,6 GHz / SSD de 64 GB ou 128 GB
MacBook will not charge.
I have tried a new charger, but it’s the same. Sometimes I get a solid Orange light, sometimes green. It stays on 0 percent, and doesn’t move.
When I look at the battery statistics it says that the capacity is 5246 and 627 cycles.
Any ideas?
Update (12/19/2018)
Imagem
The light is now green but still no charge. Its solid green.
UPDATE (07/19)
Sorry to resurect this but I’ve only just got around to a new I/O Board attempt.
Was strange as before it was always on 0 - 1 percent and not charging, replaced the I/O board and now its on 20 odd percent, still not charging, and battery is being used but going down.
Imagem
Any other ideas as I’ve tried a new I/O Board and 2 new batteries now.
Thanks!
Esta é uma boa pergunta?
Pontuação 1
11 comentários
Lets take a deep look here run this gem of an app CoconutBattery take a snapshot of the main window with the MagSafe charger connected and a second snapshot with it removed. Paste them here for us to see Adicionar imagens a uma pergunta já existente
por
try a different dc in board
por
What’s that involve, is it doable myself?
por
the i/o board guide that trevor posted
por
Did you have a liquid spill at some point? I'm thinking the charging logic within the logic board is damaged.
por
Exibir mais 6 comentários
Adicionar um comentário
Adicionar a sua resposta
andy hawkins será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Ao todo: 448
