Ir para o conteúdo principal
Guias de reparo e suporte para a sétima geração das caminhonetes Ford F-Series. Os modelos incluem a F100 (descontinuada em 1983), F150, F250, F350, entre outras.
Front signal light replacement wiring problem
I have a 1985 ford f250 and i had a bad turn signal socket so i ordered a new one amd when i got it the colors on the wires domt match up i have a brown black and blue on the replacement socket and a brown black and green on the truck my problem is I'm not sure what wires go to were if they aimt color coated please help
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@jayrodisking08
the original would be
White to indicator switch
Black to ground
Brown to the headlight switch
Since we cannot see the wiring on your replacement, you could try to connect the blue to the green, since it does have a black and brown in common. Or you can post some good images of the new lights with your question and we could possibly help you to determine the hookup for the replacement
Imagem
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Jordan McGuire será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 12
Ao todo: 926
