Replaced screen middle bottom area unresponsive
replaced broken screen and middle bottom area does response
Esta é uma boa pergunta?
The first thing to check is your connections. Disconnect the battery and then verify that you screen is properly connected and that there is no damage or debris within the connectors. If that doesn’t help, try installing your original screen to see if the issue persists.
If the original screen works fine, then you probably have a defective replacement screen.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 33
