Ir para o conteúdo principal
Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
Charging port not working
I have an ipad A1567 and can not find any info on it. The fire port needs replaced. How can I find it?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
Another option is to have the charge port replaced by a repair shop that does micro-soldering repairs. It should be less expensive than replacing the board.
Esta resposta foi útil?
Pontuação 2
From a quick search I found that your device has its charging port soldered to the motherboard. Just look in the store for the logic board of your device instead.
Pontuação 0
yes but i do not see that ifixit sells this part :(
Pontuação 0
2 comentários:
Yes but i do not see that ifixit sells it :(
por
This is the part you are probably looking for. iPad 4 Lightning Connector MAKE SURE IT IS RIGHT FOR YOUR MODEL. It should be an iPad 4th Gen Retina A1458, A1459, or A1460
por
Adicionar a sua resposta
Stephen Brackenrich será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 210
