Flashing light on handset
The red light on all handsets is flashing and there is a rapid beep as dial tone. Can still ring out and receive calls . We dont have telstra message bank activated
Esta é uma boa pergunta?
Hi @tina51 ,
What is the model number of your phone?
If it is a Uniden Dect 1760 to turn off the light:
With the phone in standby, open the menu and select Global Setup; select VMWI Reset, then select Yes.
Is the phone connected as a VOIP phone service on the NBN?
If it is then are you sure that Messagebank hasn’t been turned On? By default Telstra turns on Messagebank when on the NBN.
What do you get when you dial 101?
Esta resposta foi útil?
Thanks so much. Going to global set up fixed it . Yay. Thanks for thatt
dect 6,0 uniden
Unfortunately that's not the model number. It's the signalling protocol used by the phone.
The model number can be found on the bottom of the base station or sometimes under the battery in the phone
Press and hold the FIND button about five to ten seconds until the beeping stops.
You can also try clearing all incoming calls.
there is no FIND button on the menu?????
How do I delete messages...and stop the explitive phone from continuously from flashing?????
Últimas 24 horas: 1
Últimos 7 dias: 28
Últimos 30 dias: 82
Ao todo: 27,641
2 comentários
where is the find button
por Rhonda Pollard Compartilhar
@rhondapollard
Please confirm the model number of your phone?
por jayeff Compartilhar
