Compass/Level not working after battery + screen replacement
I repaired an iPhone 6s with a damaged screen and faulty battery. Prior to the repair, the compass and level worked correctly. However, since the repair, neither work, in addition to GPS being unable to sense the direction.
Any ideas what caused this and how to fix it? I can’t imagine that the compass itself got damaged during the repair since the logic board was never touched, so I can only guess it is something else causing this.
Esta é uma boa pergunta?
1 comentário
You can't replace the screen and battery without touching the motherboard, technically speaking, since both of those things are connected to the motherboard. If memory serves, the compass/accelerometer chipset is located directly below the battery connector. Replacing the chipset (microsoldering) would be the fix.
Here's a video showing the fix being done to an iPhone 6 mobo.
https://www.youtube.com/watch?v=uwXMW3NS...
por Steve
