Ir para o conteúdo principal
The iMac G3 came in tangerine, blueberry, lime, grape, and strawberry colors.
Is 10.3 or 10.4 better for this
I am pretty sure i picked the wrong iMac nor do i think iFixit has it listed so i will list the specs
40GB HDD(80GB when it is summer)
128MB PC100 memory (512MB or 1GB summer time)
600MHZ g3
Has 10.2.8 now but not for long!
**new harddrive is in!**(more playroom for me!
next project: upgrade the memory to 512MB or 1GB
I thought i would share this for a good laugh
On my way back from work(luckily i had 2 boxes on me),i seen this by a dumpster so i took it home and i tested it in may garage for 2 days because of my parents paranoia over my dumpster iMac
Had 10.2.4 when i got it so i updated it to 10.2.8 with NO intent to update but with limited software choices,it had to go
have to use 10.3 right now:(
At least till i can borrow a a CD-Rw that actually reads DVD-r discs
I cheated to et 10.4 on the G3
It has the stock memory and runs well!
Esta é uma boa pergunta?
Pontuação 1
2 comentários
Nick, do your installation in Target Mode with another Power PC processor Mac with a DVD drive.
por
For this iMac family I recommend Mac OS 9.2.X, you have the best performance in this way.
por
Adicionar um comentário
4 respostas
Solução escolhida
Apple iMac G3/600 SE (Early 2001) Specs
Identifiers: iMac - Early 2001 - M7680LL/A* - PowerMac4,1 - M5521 - N/A
http://www.everymac.com/systems/apple/im...
Maximum RAM 1.0 GB http://www.ramdirect.com/g3dv35.html
Maximun system 10.4.11
To use Mac OS X v10.4, your Macintosh needs:
A PowerPC G3, G4, or G5 processor
Built-in FireWire
At least 256 MB of RAM
DVD drive (DVD-ROM), Combo (CD-RW/DVD-ROM) or SuperDrive (DVD-R) for installation
At least 3 GB of free disk space; 4 GB if you install the XCode 2 Developer Tools
Esta resposta foi útil?
Pontuação 4
I'd recommend 10.4, because it's still somewhat supported (Some applications are still developed for it), compared to 10.3 (Which isn't supported at all). However, Tiger might not install on 128MB RAM. I've installed Tiger on 500Mhz iBooks without a hitch, so speed shouldn't be a problem. You may, however, want to consider installing a distro of linux, such as Ubuntu.
Pontuação 1
2 comentários:
Linux on a Motorola processor?
por
Linux can run on literally anything given enough time and changes to the kernel.
por
For this iMac family I recommend Mac OS 9.2.1, you have the best performance in this way.
Pontuação 0
what happens on summer?
It has better specs on summer?
Pontuação 0
Adicionar a sua resposta
Nick será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 17
Ao todo: 3,889
