Ir para o conteúdo principal
Modelo A1347. Lançado em 23 de outubro de 2012. Processador Core i5 ou Core i7. Apple Fusion Drive.
Adding second hard drive
My late 2012 Mac mini came with the hard drive installed in the upper bay (the one that is on the 'bottom' when the mini is upside down). I want to install an SSD drive in the other bay but can’t find the proper hard drive mounting pins. Where can I get these?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Solução escolhida
T8 TORX HARD DRIVE SCREWS - Apple Mac Mini A1347 Mid 2010 2011 2012
Apple part #922-9584
http://www.powerbookmedic.com/parts/922-...
https://www.ebay.com/itm/T8-TORX-HARD-DR...
Esta resposta foi útil?
Pontuação 6
4 comentários:
Thanks very much. Just what I was looking for. :-)
por Compartilhar
@zarkov33 - Do you have all of the other needed parts? Here's the IFIXIT kit with the cable, rubber bushings and screws. It also has the needed tools. Mac mini Dual Drive Kit
por Compartilhar
Thanks Dan,
As I've explained earlier, I am trying to install an SSD in the lower, second drive, bay. This does not necessitate anything other than a SATA cable (which I have) and the 2 mounting pins (which I need). Everything else is unnecessary as it does not require removing the logic board. Thanks for your input. Everyone has been very helpful.
por Compartilhar
@zarkov33 - Just making sure ;-}
por Compartilhar
I suggest you buy this dual drive kit for your Mac mini, it has those pins you need and it comes with the tools needed too.
Instalação do Kit disco rígido duplo do Mac Mini final de 2012
Imagem de All the hardware needed to a second hard drive to your 2011 or 2012 Mac mini.
Produto
$29.99
Pontuação 2
4 comentários:
Thanks, but to add a second drive in the lower bay(closest to wifi shield) I don't need to remove the logic board. All I need are the 2 mounting pins.
por Compartilhar
BTW, I already have the proper SATA cable.
por Compartilhar
@zarkov33 The way I suggested is the best way to go thermal-wise. Your drive may not get the proper cooling where you want to put it so I am still suggesting you get that mounting kit so you can mount it correctly.
Plus, I have no idea where you are talking about putting this nor if it will work.
por Compartilhar
I plan on adding the drive to the second drive bay (lower bay). I know it will work because the mini is designed to hold 2 drives. I've done it before.
por Compartilhar
Adicionar a sua resposta
Tony será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 56
Ao todo: 1,135
