Ir para o conteúdo principal
Um tablet Android de 10,1 polegadas lançado em 2014 pela NuVision. Seus principais recursos incluem uma tela de 1280 x 800, Wi-Fi, Bluetooth®, micro USB, mini HD, entrada para fone de ouvido e duas câmeras.
I need screen replacement
Why is my screen is unresponsive
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Make more Ram available (Delete/close unused applications that may be running> Re-calibrate screen usually found in settings> Reset (Can be found here NuVision TM1088 Troubleshooting)> Realign display (requires opening device) >then maybe a replacing something but need more info.
If you can post pictures of tablet and what it is doing that would be helpful. Is it part of screen or full screen? Is the screen damaged? What happened prior to this occurring (if you know, i have kids so i understand that “all of a sudden” it doesn’t work)?
Esta resposta foi útil?
Pontuação 1
Has the tablet said UI unresponsive? That’s when the touch screen freezes up. I just pulled my battery out and reset it on my phone but you may have to go to where ever you got said tablet from
Pontuação 0
Adicionar a sua resposta
Christopher Miles será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 19
Ao todo: 390
