Ir para o conteúdo principal
Lançado em janeiro de 2016, identificado pelo número de modelo BDP-S3700
Why does the open/close button not work
I have disconnected both the audio and HDMI cable from my device.
After turning on the device, pressing the open/close button has not effect. The green power led is on.
I have tried resetting by holding on the open/close button, and the plugging in the power cord. This did not fix the problem.
Any suggestions or advice would be gratefully received.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@igreid wonder if it is in demo mode. While the player is turned on, press  ■ (stop) , RETURN, (pause), and then the SUBTITLE  button on the remote to disable it.
You can also try to open the case by inserting a paperclip in the hole of the drive
Imagem
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thanks for the suggestion. This did not help.
This is the second unit I have had this issue with
Not sure what to do next.
por Compartilhar
Adicionar a sua resposta
Ian Reid será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 16
Ao todo: 457
