Ir para o conteúdo principal
Device repair and troubleshooting for the 7" RCA tablet released in 2014, identified by model number RCT6773W22.
My Tablet is flashing
My tablet wouldnt go on so i held the power button and yhe volume up. Now it goes on but it wont stay on and it keeps flashing. Lines flash across the screen. It shows that it is charging when plugged in.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Has the tablet been dropped or gotten wet at all?
Try disconnecting the battery, then hold the power button operated for about 10 seconds before reconnecting the battery, to see if this will reset the tablet. At least enough to be able to hopefully do something more to resolve the problem.
Here’s a link to the ifixit RCA RCT6773W22 Battery Replacement guide, which may be of some help. You do not have to remove the battery, just disconnect it from and reconnect it to the systemboard. You’ll need soldering skills and tools (or know someone who has) to do this.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Kathleen Holzmueller será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Ao todo: 2,153
