HDMI repair on insignia
How do I repair the HDMI port on my 42” Insigna flat screen..
Esta é uma boa pergunta?
clarence peska,
If your television is experiencing HDMI troubles including no signal and distorted video, see the Insignia NS-24ER310NA17 No Signal With HDMI problem page for possible causes and solutions.
First off we would need to know your TV’s exact model number. You also want to try other HDMI devices to see if it is your TV or the device (Firestick) that is at fault here. The HDMI ports are all connected to the mainboard so if it is your TV then replace your mainboard. If it is the Firestick then you will have to get a new one.
Esta resposta foi útil?
The model # for the Insignia tv is: ns32d220na8
@gabrielena31263 but what's your question? what repair do you need done? what is wrong with your TV?
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 36
Duração total: 2,349
2 comentários
Can you go in more depth about what is wrong with it?
por TechTalks
Yes I bought a Firestick and it seemed to blow out 3 of my 4 ports. I heard a small pop each time and the screen went blank.
por Andrew g Ebel
