Does your television not display video when plugged into a computer with HDMI? Is the video image distorted, blurry, or discolored when using an HDMI cable? Televisions are susceptible to a range of problems that can cause them to function improperly with HDMI connections. Check the following possible causes to identify and solve the problem.
HDMI is Not Plugged in Correctly
If your TV is not finding an HDMI signal from the HDMI port, it may need an HDMI reset. To reset the television’s HDMI, unplug both the TV and all other connected devices. Then, disconnect all of the HDMI cables from both ends and reconnect them. Lastly, plug in all of the connected devices to the power. Give them about 30 seconds to boot up before plugging in the TV.
Incorrect Resolution
If your TV’s video is distorted when using an HDMI connection, the computer may be operating at an incorrect resolution. To fix this, double-check the Resolution settings by right-clicking the desktop, and selecting “Screen Resolution.” The ideal resolution for every computer is different. To change the resolution settings of your computer display, go to settings, display, advanced display settings (if you cannot currently see a setting for the resolution), and change the resolution to best fit the TV. Play around with different resolution settings, until you find the one that looks the best on your TV.
Questions other people have asked about this
- HDMI repair on insignia
- How do I repair a Sony KDL-52XBR4 HDMI port.
- Why is my picture too big?
- Sony KDL-52W5500 No HDMI Picture or sound
- How to check TV Sony Bravia KDL-26S2020 HDMI port and change it?
4 comentários
Your hdmi fix doesn’t work!!!
pricejeanette15 - Responder
Your hdmi fix it doesn’t work!!!
HDMI not working
Brianda Todd - Responder
Does not work
Kevin Basler - Responder
