Ir para o conteúdo principal
Uma reedição do Nokia 8110 original, este celular foi lançado em 2018, também conhecido como o Celular do Matrix.
How can I remove wifi chip?
Hello,
I want to buy my son the new banana phone, but I cant trust him with wifi accessibility,
is it possible to remove the wifi chip on the phone?
Thanks,
Mendel :)
Esta é uma boa pergunta?
Pontuação 0
1 comentário
אני לא מצליח לצפות בסרטון הדרכה אם אפשר לשלוח לי אותו
Google translate:
I can't watch a tutorial video if it can be sent to me
email address removed to prevent spam being sent- moderator
por
Adicionar um comentário
3 respostas
Pergunta mais útil
It's an easy teardown but not much for information in regards to a chip for wifi. Most parts are soldered to motherboard.
I'm not sure what it is capable of, but an app is probably more of what you need. There is one I've used “screen time parental controls” which controls screen time. App access, sees browsing history, and you can shut down usage if need be by schedule or instantly via your
Desmontagem do Nokia 8110 4G
Esta resposta foi útil?
Pontuação 3
Hi @nhfh
Check if the mobile data setting has been selected for the correct SIM card
Go to Settings  >  Network & Connectivity  >  SIM Manager.
Choose which SIM to use for mobile data, select  Data , and select  SIM1  or  SIM2
Pontuação 1
You cannot remove WiFi chip. It's SoC so everything is in one chip which is named Snapdragon 205.
Pontuação 0
Adicionar a sua resposta
Mendel Goldstein será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 33
Ao todo: 930
