Ir para o conteúdo principal
Guias de reparo e informações sobre caixas de som Insignia.
Broken speaker plastic connection wire clips - +
I have 2 never used 4 inch three-way surround speakers. The wire connection spring tab in the back is broken. The spring loaded plastic connection tab on the back of the speaker broke off. This is where you plug-in the positive and negative wire. The negative tab is broken on each speaker.
I need 2 wire connection units?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi @jeffgray ,
Here’s a link to suppliers of the type of terminal connector that I think that you’re asking about.
Hopefully, by scrolling down the page, you’ll be able to find a suitable replacement part.
If not, post some pictures of what your connectors look like (add dimensions if possible and also the model number of the speakers) and perhaps someone will be able to find an appropriate replacement.
Here’s how to do this. Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jeff Gray será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 2,316
