Home button very hot and works sometimes
Hi
I repaired a iphone 7 screen and I was VERY careful with the homebutton.
But now the homebutton doesn’t work anymore, sometimes it does and than it register more presses with only one press.
TouchID & Reachability works perfectly fine.
And the left part of the homebutton is very, VERY hot. It also sucks power…
I have read a lot of things about the broken chip on it, but isn’t there a solution without soldering?
I was so careful, I can’t believe that I broke it?
Thanks in advance
Esta é uma boa pergunta?
1 comentário
With heat, my first suspicion would be a short circuit. Check to make sure the home button connector is properly seated in its socket, and that the bracket isn't shorting out against anything (steps 21-25 in this guide). If all looks good there I would examine the home button assembly under a magnifier, looking for damage (cracked chips, missing pieces, etc).
iPhone 7 LCD and Digitizer Replacement
por Steve
