Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2264 Perguntas Visualizar todos
iPhone 7 not charging and earbuds do not work
It does not charge anymore, it is not detected in itunes, however if I heat up the battery with a blowdryer it charges on the red battery icon but stays there. Earbuds did not work when it was on. It was playing music earlier then I unplugged my headphones and it stopped working all of a sudden. Is it a bad Tristar IC or is it a lightning assembly issue?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Adicionar um comentário
2 respostas
Solução escolhida
It was a bad lightning connector assembly. I charged battery externally with a battery tester and backed up my data.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
It could be the charging dock,you should test it before even think about a bad tristar.
Pontuação 1
5 comentários:
any way to test it?
por
iPhone 7 Lightning Connector Assembly
Don't need to change it all,just disconect the old piece and conect/plug the new one. Then you'll know if it is or it is not.
If it work,replace your charging dock.
If not,post results we'll try to help.
por
will do, I ordered a dock replacement coming in tmrw, also got an external battery charger so I can charge my battery and back up my data to cloud
por
Good call! Post results and let us know if it worked!
por
Yes! it turned out to be a faulty lightning assembly. Thank you for all your help!
por
Adicionar a sua resposta
Tony Tat será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 147
