Incorrect charging of tablet
Accidentally charged tablet with a 12 volt charger when it required a 5 volt charger.
Esta é uma boa pergunta?
Hi @timzach ,
You need to open the tablet and inspect the motherboard for any damage.
Here’s a link to the ifixit Substituição da placa-mãe do Polaroid P902 guide, which may be of some help.
You don’t need to actually remove the motherboard. The guide is just to show you how to open it to gain access.
If there is any obvious damage, e.g. burnt out/blown components etc or if you are not sure take some close up pictures of the problem area and post back here and hopefully someone will be able to help. Here’s a link that shows how to do this.
Guia
Nível de dificuldade:
Muito fácil
2 - 5 minutes
Guia
Moderado
30 minutes - 1 hour
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 26
Ao todo: 342
1 comentário
Did it instantly die when you plugged it in, or did the battery just drain and couldn’t charge it.
por Leo Catalano Compartilhar
