Ir para o conteúdo principal
Guias de reparo e suporte para a picape compacta Ford Ranger da 1ª geração revisada. A Ranger recebeu uma reestilização e algumas atualizações mecânicas para o ano-modelo 1989.
4 years without being started
Just replaced the fuel pump ,battery and emptied the gas tank put new gas but it still wont turn over , spark plugs are good as well as the coils and along with the spark plug wires& new relay . The fuses are good .has an after market alram system that no longer works with the clicker batteries were replaced .any one whos dealt with this kind of problem id appericate some help
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Phillip Griego let us know what works. Do the lights come on? Do you have any sign of life on your Ford?
por Compartilhar
You said it wouldn't turn over. Do you mean there is no "cranking" when you turn the key, or that there IS cranking, but it does not start?
por Compartilhar
Adicionar um comentário
1 resposta
You may need to pull the plugs and carefully hand crank the engine to break the vacuum seals and varnish buildup on the cylinder walls & pistons. When you store a engine for over 3 months you really need to add in an additive to the gas and fully fill the tank and you need to put oil into the cylinders to coat the walls (doesn’t take much).
Edmunds - How to Prep Your Car for Long Term Storage
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Phillip Griego será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 8
Ao todo: 330
