Ir para o conteúdo principal
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
No Keyboard function after reassembly
Hi there
I spilled some gin on my Macbook, immediately opened it, cleaned it with a paper towel to dry and then with some IPA.
Heres the thing, except the Keyboard, wich worked before, everything seems fine.Even the Backlight of the Keyboard is working properly
cheers Guys
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta mais útil
There are numerous videos on how to replace just the keyboard on this model. Lots of labor but only about $25 for a good part. Here’s one:
how to replace the keyboard on a macbook air 2011
Esta resposta foi útil?
Pontuação 2
Did you have some tonic water with it and the Lime? :-/
Sorry to say you’ll need to replace the uppercase to fix this MacBook Air 13" (Mid 2011) Upper Case with Keyboard. Here’s the guide you’ll need to follow MacBook Air 13" Mid 2011 Upper Case Replacement
Imagem de Replace an upper case assembly compatible with the Mid 2011 MacBook Air 13 inch laptop. Includes the keyboard, palmrest area, and power button.
Produto
$49.99
Pontuação 1
Hey mate
Id recommend removing your motherboard and cleaning it.
Drying out water damage is really what you want to avoid, your only speeding up the corrosion process. The board needs to be cleaned not dried.
You can use Isoprophyl Alcohol and a toothbrush at the very least.
or EC cleaner & distilled water
Pontuação 1
Adicionar a sua resposta
Andreas Schmid será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 13
Ao todo: 125
