Ir para o conteúdo principal
Guias de reparo, informações de desmontagem e resolução de problemas para a 5ª geração do Apple iPad com 4G LTE, disponível com 32 ou 128 GB de armazenamento. Lançado em março de 2017. Identificado pelo número de modelo A1823. Possui tela Retina de 9,7" e processador A9 de 64 bits.
Is there a board view for the iPad 5 LTE?
I went to replace the tristar chip on this board, and accidentally knocked off a component next to tristar. I couldn’t find the component to put it back, and I didn’t pay enough attention before hand to know what it was, nor do I have a donor board for this model. I decided to test if it might have been a filter capacitor or something, and reassembled things, just to get a boot loop, so I need to find out what the component was and replace it. It was likely either a resistor or a diode, but I’m not sure.
ZXW tool and Easy Draw both have schematics and board views for the 4th generation iPad and the iPad Air/2 models, but they don’t seem to have the 5th gen schematics and board view. On the other models, it appears that there are a couple zero ohm resistors in that area, but things look different enough I don’t want to just try it without more information.
Is there a board view for the iPad 5 so I can figure out what the components are surrounding tristar on this board?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
As far as I know, there is no publicly available board view for this model. However, the Tristar circuit is pretty much a universal design since it’s introduction and the iPad 5 is essentially an updated Air (even iFixit has used the same guide with with a different title!).
So what I would do is do a little bit of reverse engineering and see what exactly this component connects to and find the same thing in the Air documentation.
Esta resposta foi útil?
Pontuação 2
3 comentários:
It seems iPads in general are quite a weak spot with ZXW boardview, the iPad 3 is incomplete, the Air misses power/data lines references..is Easy Draw any better ?
por Compartilhar
@arbaman Actually, the last time I checked (about 2-3 months ago), EasyDraw has less info when it comes to iPads. I just received a dongle for Wu Xin Ji so I'll check that out. I should write up a blog post on this :>).
por Compartilhar
Good to know, thank you. I'll keep an eye out for your blog news :)
por Compartilhar
you can go to www.jcprogrammer.com/download install JCID repair operation platform, in the software you go to JCID Drawing, then you choose the board you need, there is iPad mini 1 to iPad pro 5gen also all iPhone model !! Of course its not free but not too expensive.
Imagem
Pontuação 1
What Tristar did you use? Is it the same as the 7/7+ or is it the same as the iPhone 6/Air 1??
Pontuação 0
Adicionar a sua resposta
Timm Simpkins será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 47
Ao todo: 1,712
