Ir para o conteúdo principal
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Perguntas Visualizar todos
Phone makes calls, but no audio is sent or recieved. The call does go.
I have reset the phone multiple times and tried it on multiple carriers. It will sucessfully place the call, and the receiving party can anwser the call. There is no option to change audio source, usually the top right button in a call.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
The iPhone 7 series of devices have proven to be very unreliable, suffering from flex-based issues similar to the iPhone 6 Plus (Touch Disease). On the iPhone 7, the fault line runs along the top of the SIM card reader and affects the Baseband CPU and Audio IC. There are a few copper traces running perpendicular to the fault line that connect to the Audio IC that are subject to failing.
Here are the typical symptoms, as collated by the repair community:
  1. Voice Memos app / Loudspeaker on call - greyed out
  2. Siri doesn’t hear you / Caller can’t hear you
  3. Most other Audio related issues that aren’t solved by modular replacements
  4. Long boot times (3-5 minutes)
  5. iTunes detects the phone but stuck on the Apple Logo
This requires a micro-soldering repair and is not a DIY fix.
Esta resposta foi útil?
Pontuação 1
3 comentários:
Any details on the repair? Videos? I can only imagine that it would be a band aid at best since the phone will likely flex and break in the same way again.
por
I should have said it first, but thank you.
por
Micro-jumper repairs are long-term repairs and not bandaids. The copper traces on an iPhone circuit are incredibly thin and break pretty easily. The jumper (50AWG/0.02mm) that we put in place, while tiny by normal measures, is huge comparatively. The repair community has been doing this for several years on Touch Disease issues and the return rate is essentially nil.
por
Adicionar a sua resposta
Harold será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 81
