Ir para o conteúdo principal
The Galaxy Tab S2 9.7 is a tablet released in 2016 by Samsung. This device comes in both 32GB and 64 GB variants. The Wi-Fi only model number is SM-T813. The factory unlocked 4G model number is SM-T819.
16 Perguntas Visualizar todos
Tablet damaged by water
my tablet is samsung Tab s2 9.7 and it damaged by water so touch it’s perfectly work whole screen but the bottom of screen its kinda dark but not very dark like you can see the items ,so what should i do ?it needs new lcd?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
John Watson  the very first thing you want to do is stop using it. Then disassemble it using guides like this Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement. Clean everything with a high grade isopropyl alcohol 90%+ and a soft brush. Use this guide Repairing iPhone Liquid Damage for that. It was written for an iPhone but all the points are still pertient to yours as well. Once done, you could reassemble it to re-evaluate or you can take your chances and repalce the screen Samsung Galaxy Tab S2 9.7 SM-T813 Screen Replacement since it seems to have taken most of the damage.
Imagem de iPhone
Guia
Nível de dificuldade:
Difícil
1 - 2 hours
Imagem de Samsung Galaxy Tab S2 9.7 SM-T813 Screen
Guia
Moderada
20 minutes - 1 hour
Imagem de Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard
Guia
Moderada
1 - 2 hours
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
John Watson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 699
