Ir para o conteúdo principal
Haswell business laptop introduced by Dell in 2013. This system is notable for being the first Haswell business laptop released, but has multiple known problems - including AMD GPU failure. A new battery will operate the laptop for ~4-7 hours, depending which one is installed.
replacement keyboard not working
Hi there,
I have recently replaced my keyboard with a non-original keyboard and it works only a few minutes and stops. After every BIOS update it works again and stops after a few minutes.
Any idea how i can get this non-original keyboard to work?
Regards,
Siviwe
Esta é uma boa pergunta?
Pontuação 0
1 comentário
You tried to use your keyboard in safe mode if it is working then there must be an app causing error
por
Adicionar um comentário
1 resposta
Solução escolhida
Need to try a DriverPack Solution Software and update the keyboard driver. If the problem persist your new keyboard might have a defect.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Siviwe Xegwana será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 14
Ao todo: 245
