Ir para o conteúdo principal
Samsung's flagship phone, the Galaxy S8. Released in April 2017.
Screen: Glass LCD or both?
So I've been researching how to replace my Samsung Galaxy S8 glass/lcd. How do I know if it's just the glass or if I replace the glass, I have to replace the lcd as well? I survived 3 years of my Samsung Galaxy S6 without damage, and a little over a year with my S8, I dropped it from the seat of my truck to the ground (Incipio case and Zagg Sapphire Defense screen protector on) and it splintered from the lower left corner. Imma crying
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
@ajleung
the LCd and the glass are fused. Unless you have the right equipment to separate those parts and have the right machine to re-adhere them into one assembly, replace the complete assembly. Use this guide Samsung Galaxy S8 Screen Replacement for the work and the part is available right here [produto vinculado ausente ou desativado: IF355-001]
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Depends on what you can and cannot do. Removing the Glass itself is really tricky and requires some special tools and experience. If you're willing to try a DIY replace the entire LCD.
Doing this phone'sdisplay is rather tedious, especially if it's your first time. Check in with a local repair shop and see what it's going to cost you.
You may also want to check if that tempered glass you got has some type of warranty on there. I've noticed some companies are trying to stand by their product if their tempered glass fails to protect your screen.
good luck
Pontuação 1
Adicionar a sua resposta
Adrian Leung será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 3,051
