Ir para o conteúdo principal
Why Is My Phone Stuck on Boot Loop After Liquid Damage?
Hi, first of all I would like to say I'm not looking for simple answers, i.e - hard reset, disconnect / reconnect battery. I would like to know if anyone out there, all be a technical genius could answer my question and give me some pointers. Now I'm no professional at phone repairs but I've done a fair few to understand the basics. I've never done any IC soldering / repair nor can I due to lack of equipment.
Basically, my question is this: Why is my iPhone 6 stuck on a boot loop when plugged into mains power but will not turn on independently via usb to pc or by it's own battery (new battery). The phone I believe has suffered water damage and after inspecting the pcb I noticed a scorch mark on the lower part of the board's shield. I have no idea what IC's to look at or what areas to look at first.
I've noticed that some of those IC's have suffered some damage and I believe maybe some of the board's ceramic caps are missing / damaged. I only have a soldering iron and a conventional multimeter, so any starting point would be good.
Any information regarding that would be great. Thanks.
https://ibb.co/heom3d
https://ibb.co/dPM63d
https://ibb.co/gmPFwy
https://ibb.co/fXWvwy
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
ok brandon your phone can bootloop with shorted components but finding the actual component can be difficult if you don't have a dc power supply. i suggest you take a look at the capacitor to the left of the wifi chip even if you knock it of the phone will still work
Esta resposta foi útil?
Pontuação 2
2 comentários:
Thanks. Do you by any chance know where I can find a diagram / schematic of the iPhone 6 logic board? I don't know where what IC's sit where.
por
possibly a zxw file type from gsmforum
por
Adicionar a sua resposta
Brandon Frost será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 83
