Ir para o conteúdo principal
Processador de 1,86 GHz ou 2,13 GHz, armazenamento flash de 128 GB ou 256 GB
Trackpad and Keyboard ghosting
Imagem
Since some days my MacBook Air 13 Inch Late 2010 has a problem.
Both the Trackpad and the Keyboard do some entries without typing or clicking anything.
Its like somebody types on my keyboard or uses my trackpad without any physical input.
I wonder if the problem is not the keyboard or trackpad itself because both of them started to act weird at the same time.
Is there maybe a cable that could be responsible for this?
Would be glad if someone ever had the same problem and hopefully a solution.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Yours system uses a single cable to send the keyboard & trackpad signals to the logic board. What can happen is the battery swells pressing on it. I would first recommend checking your batteries health using CoconutBattery paste a screenshot of the apps window here for us to review Adicionar imagens a uma pergunta já existente depending on what this shows you’ll likely need a new battery. Substituição da bateria do MacBook Air 13" de final de 2010
Another source of problems is the trackpad its self as its the junction point for the cables. a liquid spill can mess up the trackpad or if the liquid gets to the back side mess up both. At this point you’ll need a new trackpad and you may want to replace the cable as well. Substituição do trackpad do MacBook Air 13" de final de 2010
Imagem de MacBook Air 13" Late 2010 Bateria
Guia
Nível de dificuldade:
Moderado
15 minutes
Imagem de MacBook Air 13" Late 2010 Trackpad
Guia
Moderado
Imagem de iFixit
Guia
Muito fácil
2 - 5 minutes
Esta resposta foi útil?
Pontuação 1
4 comentários:
Hello Dan
Please check the screenshot attached :)
por
It looks OK, you'll need to replace the trackpad & its cable
por
OK and you are sure that its not only the cable but also the trackpad? How is it possible that also the keyboard acts so weird? :(
por
OK, Lets think it like this: A cable to B cable to C where A is the keyboard and B is the trackpad and C is the logic board.
So A & B can encounter problems if the cable between B to C is bad. Its also possible A and B can encounter problems if B its self is bad. Does that help in visualizing the issue?
We are replacing the two elements that can effect both the keyboard & trackpad.
por
Adicionar a sua resposta
jimmy industries será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 28
Ao todo: 1,896
