Ir para o conteúdo principal
Guias de reparo e suporte para a memória de acesso aleatório usada em computadores.
What does the missing chip do
== Hello i have a Samsung 1x 8GB DDR4-2133p that lost a chip==
the problem is that under shipping one of the small chips on the backside for it got damaged, and i wound if it could be fixed or if it's just trash now.
i have add 2 pic of the ram in questing, with a working par about the one that lost its chip in the first pic
Imagem
Imagem
Link to the Ram from samsung.
https://www.samsung.com/semiconductor/dr...
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
LoD-RoG  those are resistors and, unless you can measure the one next to it, pretty impossible to replace.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Your right! Its a dual resistor. It is 4-pin resistor array, two resistors, value 15 ohms each
por Compartilhar
Pergunta mais útil
Sorry to say getting one of these small inductor coils will be difficult, likely not salvageable.
You said it came off during shipping. What this loosely packed and mailed? if that is the case I would see if shipper has insurance or if the seller will accept it as a return,
Pontuação 3
Adicionar a sua resposta
LoD-RoG será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 25
Ao todo: 1,013
