Internet connection not working
My router is working fine but it cant get an internet connection. I've reset it multiple times
Esta é uma boa pergunta?
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 31
Ao todo: 1,042
Hi @dgold44 ,
Has it worked OK before?
Can you connect to the internet when you are directly connected to the modem?
por jayeff Compartilhar
Yes it works perfectly fine then sometimes at night it just completely stops working.
por Dawson Goldsberry Compartilhar
Hi @dgold44 ,
Just to clarify, it is the router that loses internet connection not the modem, is this correct?
If it is the router is it still showing as connected to your computer, even though there is no internet connection?
Have you tried a different WiFi channel (change in router) just to see if it behaves the same?
Have you checked that your model router has the latest firmware installed?
