Ir para o conteúdo principal
Informações de reparo para o smartphone Sony Xperia X, anunciado em fevereiro de 2016 e lançado em maio de 2016. Este celular faz parte da série Xperia X de telefones da Sony.
Phone Screen not working (no touch)
Hello!
A while back, I dropped my phone in water and immediately disassembled it to dry it off. The symptoms were a screen that either worked perfectly after reboot and then turned black every time the screen was turned on, or a perfectly functional device except that the digitizer did not work. So, after reading some "advice", I soaked my screen in 91% alcohol, leaving permanent marks. Then, I soaked the logic board in alcohol with a vibration assist from a washing machine. The logic board seemed to be fixed, and being a perfectionist, I tried to go a step further by using a food dehydrator to dry the alcohol marks out of the screen. However, after a while of drying (of screen only, vacuum sealed into a container with silica gel and dessicants), the screen digitizer does not work anymore.
My question is this: is the problem with the screen or the logic board? I noticed that some antenna contacts were slightly bent out of shape, but I am not sure what happened to the rest of the board. There doesn't seem to be corrosion. Keep in mind that after the laundry machine vibration, I took the board out of alcohol, but after I discovered the screen issues, I put it in for around 24 hours.
If needed, I can send photos.
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 0
1 comentário
OK, I am actually out of state right now, I will post once I get back. Yes, I will order the replacement screen later.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
@froggr123 just add your pictures to the question. Use this guide Adicionar imagens a uma pergunta já existente for that. Going by your description alone it sounds like the issue is with your display assembly. I would go ahead and replace that. If the error is on the motherboard, then there is only a slim chance of repair. You would need a schematic which is not available. Sony simply does not have those anymore. Replace the screen and re-evaluate Substituição da tela LCD do Sony Xperia X
Imagem de iFixit
Guia
Nível de dificuldade:
Muito fácil
2 - 5 minutes
Imagem de Sony Xperia X Tela LCD
Guia
Moderado
Esta resposta foi útil?
Pontuação 2
2 comentários:
@oldturkey03 I will upload images tomorrow (just got back from out of country). Will order screen later from Amazon. The WitRigs screen does not have a frame, and I don't want to detach the frame for safety reasons. Hopefully the screen is legit. Thanks!
por
Adicionar a sua resposta
froggr123 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 18
Ao todo: 501
