Ir para o conteúdo principal
Informações e guias de reparo para a versão atualizada do Retina MacBook de 2015, lançada no início de 2016. Modelo A1534 / EMC 2991
No output devices found
Hello All,
I recently installed a new display assembly on the macbook and had some issues. I finally got the display working when i realized that the audio cable was in backwards pins side up instead of down (dumb mistake). When i put everything back together I was worried that the sound may not work. sure enough its not working. not internal speakers are seen by the computer. the error is no output devices found. I reset the PRAM. and even reinstalled OSX. I have checked all my internal connections to the logic board. i ran a hardware diagnostic and its not seeing any issues. I am worried that the audio board and the cable might be fried... any ideas would be awesome.
PS. plugged in headphones and no go.
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
I know this question is old but you most likely tore the audio board flex cable when you disassembled the machine
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Yelitza rodriguez será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Ao todo: 731
