Ir para o conteúdo principal
Lançado em junho de 2012 / processador Core i7 com Turbo Boost / até 1 GB de VRAM GDDR5
Battery not holding a charge
Hi!
I purchased last week the battery replacement kit from iFix for my Mid 2012 MBP. Swap went smooth, just like the article explains it. However, I've noticed that after the battery is fully charged. it doesn't hold the charge. I left the laptop with about 80% last night, shut it off, when I turned it back on this morning, it immediately dropped to 6%.
Is there a reset or a software step I have to take after the new battery is installed? Thank you for your help in advance!
Rafa
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
3 respostas
Pergunta mais útil
I’d download, install run and post your finding using Coconut Battery so we have a better idea of what is happening
https://www.coconut-flavour.com/coconutb...
Esta resposta foi útil?
Pontuação 2
You can try a SMC reset. https://support.apple.com/en-us/ht201295
Pontuação 1
Dud battery. Was it doing the same thing prior? If not, get this battery swapped. Dud batteries happen.
Pontuação 1
Adicionar a sua resposta
Rafael Otero será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 30
Ao todo: 646
