Ir para o conteúdo principal
Guias de reparo e resolução de problemas para o Dell Alienware M17x R4, a 4ª versão do notebook gamer Dell Alienware M17x.
How to remove M.2 ssd.
where is m.2 located om M17 r4.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
4 respostas
Pergunta mais útil
If nothing else, download the user manual from here [http://downloads.dell.com/manuals/all-pr...|Owners manual] It includes instructions for the removal of all parts.
Update (06/01/2018)
M17 R4 SSD card is under the top cover. You have to remove the cover/touchpad/keyboard to get to it.
Imagem
Check this mislabeled video for more info https://www.youtube.com/watch?v=aXzvIwaB...
Esta resposta foi útil?
Pontuação 2
3 comentários:
Hi, already have user manual and nothing there .
por Compartilhar
I think there is an overall confusion right now about what model your computer is and where the SSD is. I suggest that you remove the cover of whatever model computer you have and post some pictures of what you see. That way we can at least all be on the same page.
por Compartilhar
M17x R3 and R4 are not M17 R series.
M17x R3 and R4 have a mini pci slot (only sata2 speed) for ssd , not M2 slot
por Compartilhar
It sounds like you have the newer version of the system.
Here’s a good overview of the drive locations and what is needed: Inside Alienware 17 R4 – disassembly, internal photos and upgrade options
Pontuação 1
3 comentários:
Hi, and thanks' for the reply.
I have the M17 R4 this is a older model. You posted the 17 R4. 17 R4 is a newer model.
por Compartilhar
I do hate it when they reuse the same model name with a slight difference ;-{
If you have the older model then I believe your system only has a support for dual 2.5" SATA drives not M.2.
The M17x R4 model in-between this one and the one in the guide has a single mSATA M.2 bay just under the bottom cover.
por Compartilhar
Older model yes. And it does have a M.2 ssd.
por Compartilhar
Try checking out the notebookcheck review of the M17 R4. Notebookcheck usually has a partial teardown in their review. In this case, there's some photos of the bottom of the laptop disassembled. Check it out here:
https://www.notebookcheck.net/Alienware-...
Pontuação 0
1 comentário:
Hello, could not find anything about notebook check.
por Compartilhar
It is listed in the user manual I got for my M17 R4 in 2021 with an NVME m.2 and 307 graphics card. Not sure which one you got but check this out.
https://dl.dell.com/topicspdf/alienware-...
Pontuação 0
Adicionar a sua resposta
orte7e será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 34
Ao todo: 2,876
