Ir para o conteúdo principal
Reverse camera RCA cable
Hi There,
I have panasonic cn-hds625d and need to get a RCA cable for the rear view camera. Please advise what is that slot type called and where it is available. This car is currently in Newzealad and it is an Japan Import car
Sorry. Missed to update the image... adding it now.. Please also where i can get these cables in Newzealand.
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
'''++ttsenkumar kumar++''' not quite sure which slot you are talking about. I suppose you are referring to the rear camera slot. You can always post some images of what you are looking for with your question. Use this guide Adicionar imagens a uma pergunta já existente for that. That is most likely proprietary and without a proper schematic it will be extremely difficult to source it. I do believe that there is a rear camera kit for your navigation model Check for something like YESFX999101
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks Mate... Just added the picture
por
Adicionar a sua resposta
ttsenkumar kumar será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 21
Ao todo: 700
