@pcsiqueira DLP0NS is a common mode choke coil from Murata. In this case it is a DLP0NSA150HL2 Just an FYI, this is what that means:
DL = Chip Common Mode Choke Coils
P = Film Type
0N = (LxW) 0.85x0.65mm
S = Magnetically Shielded One Circuit Type
A = Category
150 = Impedance
H = Circuit
L =Feature
2 = 2 Lines
Both Digikey.com and Mouser.com carry those but only sell them in quantity of 1,000. You could always try on finding some kind of donor board and getting them of there, or try to match the choke as closely as possible with other manufacturers etc. Here are the values to look for:
Common Mode Impedance = 15ohm±5ohm
Rated Current = 100mA
Rated Voltage = 5Vdc
Insulation Resistance = 100M ohm
Withstand Voltage =12.5Vdc
DC Resistance = 0.95ohm±25%
