Ir para o conteúdo principal
Lançado pela Lenovo em outubro de 2015. Identificado pelo número de modelo ZA0H0022US.
lenovo tab2 not starting
My Lenovo tab 2 is not turning on and not even the light around the power button is turning on on powering or charging I tried every thing even removing the back of the tab and removing the battery connector and then again connecting it but is still does not work any one has any idea so pls help
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
I have the same problem with my tab right now.Hopefully someone with the answer will answer soon...
por
Hi @flyz_g ,
Just so we're on the same page.
What is the full model number of your tab as there is a tab 2 and a tab 3 being shown above? (tab 2 in question, tab 3 in linked device image which is chosen???? by the person who wrote the question)
I realize that there is no tab 2 option available when choosing the device when asking a question but it does add to the confusion
por
Adicionar um comentário
1 resposta
I had that issue too, was about to give up after a couple months that I was unable to resolve. Luckily I landed on a forum that mentioned to be sure to use only the original charger AND cable that was supplied with the tab. I went on a hunt to find them and sure enough it was charging again and all is well. If you don’t know where you put both just buy a replacement.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Boss será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 12
Ao todo: 433
