Ir para o conteúdo principal
Guias de reparo para máquinas projetadas para se mover lentamente e realizar grandes tarefas, incluindo veículos agrícolas e de construção destinados a funções especializadas.
Manual PTO not engaging blades
Hello - I have a White Outdoor LT-1650 tractor. When the tractor has been running for 15 mins or longer, the manual PTO will not engage the blades. I replaced the belt and spring thinking they may have become stretched out. This didn’t solve the problem. The engine pulley is spinning fine. When I turn the PTO lever, the pulley pushed out fine. It just doesn’t seem to be putting enough pressure on the belt. I can’t find any other adjustments that would solve this issue. Any help would be great.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
@mjones21 besides checking the idler pulley you also need to check the routing of the belt, the connection of the springs, the engine pulley and the pulley's on the deck. Make sure that all of those are in working order, not seized etc.
Imagem
Esta resposta foi útil?
Pontuação 2
Pergunta mais útil
You have an idler pulley that has moved out of place or is seperated/seperating. Very careful inspection will tell you. Look for NEW wear marks on pulleys. Check springs too. Good luck
Pontuação 2
1 comentário:
Inspect the manual PTO lever, if it rests mid way when disengaged it may have become bent. Replacing lever may be necessary for proper operation.
por
Adicionar a sua resposta
Mark Jone será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 4
Últimos 30 dias: 19
Ao todo: 2,788
