Ir para o conteúdo principal
A nova geração do Santa Fe 2007 estreou no Salão Internacional do Automóvel da América do Norte de 2006 em Detroit.
How to replace radiator
how fixed water tank
Esta é uma boa pergunta?
Pontuação 2
5 comentários
what year is the santa fe
por Compartilhar
A 2012 Hyundai Santa Fe, have radiator leak, replaced top hose already, still leaking. Can't find a Youtube video for 2012 Santa Fe.
por Compartilhar
Just to know how to repaired
por Compartilhar
How to fix or replace radiator
por Compartilhar
@Martin Caine
What is the year model of the vehicle?
What's wrong with the radiator?
por Compartilhar
Adicionar um comentário
2 respostas
Pergunta mais útil
Here's a video on how to do it:
https://www.youtube.com/watch?v=apAy-nfb...
Esta resposta foi útil?
Pontuação 1
1 comentário:
While this video is pretty decent, it's for the 2006 model which has some significant differences. I'll have to verify on a 2009, but IIRC the top core support on the 2007 and later doesn't just pop off with 4 screws as shown here.
por Compartilhar
@lilirishpol ,
Did you check for any coolant stains around the base or seams of the radiator or around the radiator neck etc?
If around the base of the radiator you may have a leaking radiator core or if on the neck of the radiator, a faulty radiator cap.
Get the cooling system pressure tested to see if the leaks show up.
Pontuação 1
Adicionar a sua resposta
daniel paintsil será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 48
Ao todo: 11,671
