Ir para o conteúdo principal
O Alcatel One Touch Idol 3 possui uma tela de 5,5 polegadas, 1080 x 1920 pixels, equipada com um processador de 1,5 GHz. Lançado em junho de 2015. Modelos 6045Y, 6045K, 6045O, 6045I.
Why does phone gong instead of ring?
I have an Alcatel One Touch Idol 3. Occasionally, instead of ringing like it should (using the ringtone I selected as default) the phone just gongs slowly. It particularly happens when my son calls (I have no idea why). The problem is that the gonging sound is quite low in volume, and I almost always hear it too late to answer in time. Does anyone else have this problem, and if so, how can I fix it?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi Joe,
Has the gonging ever happened when someone other than your son called?
por
Adicionar um comentário
2 respostas
If the ring tone only makes that sound when your son calls and with no one else , then it sounds like you or your son set the ring tone to that sound. You can set different ring tones to each individual contact. All you have to do is go to your son's contact, click edit, scroll down to were it shows ringtone, and then change it or set it back to default.
Esta resposta foi útil?
Pontuação 0
I already checked that. The ringtone was set to default.
Pontuação 0
Adicionar a sua resposta
Joe Perrone será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 25
Ao todo: 294
