adhesive in repair kit not working well
I replaced the digitizer and screen for an ipad Air using one of the IFixIt kits, and it all worked well except there is one area on the right side near where the digitizer cables are located that doesn't appear to be adhered as well as it could be. When you push down on the edge you can hear the adhesive stick and then eventually a bit later it will unstick with a small clicking sound. Is there a liquid adhesive I could use by pulling up on the glass a bit and injecting underneath in that one little area? With a syringe-type applicator or something similar? Thanks.
Esta é uma boa pergunta?
1 comentário
Well that was an abject failure. The digitizer has what looks like bubbles in it, almost like when you get dust underneath a screen protector. I think when I nudged the cable off the ledge, it disconnected from the strip on the digitizer. I don't think there's any coming back from that....
por mark fitzgerald
