Air charging pin 37, where?
I have an iPad Air with damaged pad. Pin 37. PPVBUS E75.
Someone know if there is any point I can make a jumper for this pad?
Would help me a lot, thanks!
Esta é uma boa pergunta?
This should be pretty easy to jumper, just look at the highlighted area of the attached image.
IMHO, if you are doing any type of micro-soldering on an iPhone, you should absolutely have the schematic on hand. It's pretty easy to find if you search on Google (sorry, can't share them here).
Esta resposta foi útil?
So, basically I can just connect 37 with 39 and I’ll be fine?
Yep, 35 or 39.
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 12
Duração total: 218
