Can the speaker be replaced?
My speaker is very distorted when I turn up the music.
Where can I get a replacement speaker?
Thanks!
Esta é uma boa pergunta?
Thanks!
Hi @artvalder ,
Did you try using headphones at all?
When you say radio, is this both for AM as well as FM?
Only ask because FM is usually stereo and AM is not (although it can be).
If AM is OK and FM not then there may be a problem with the amp, but without a schematic (given nowadays the amp is most probably is contained in a 'chip') it may be difficult to locate.
Can only suggest that you open the speaker and check for any obvious problems,e.g. heat stressed components or bulging capacitors etc.
Be sure to disconnect the battery in the speaker before you start looking about as you don't want to cause anymore problems than what you have already.
If you suspect something is amiss take close up pictures and post back here and somebody may be able to help. Here's how. Adicionar imagens a uma pergunta já existente.
Also try and find the 'board number' printed on the main pcb as this may help in finding more info regarding the speaker.
Sorry that I can't be of more help at the moment
Esta resposta foi útil?
I found a physically identical 2.5" speaker, but it is 8 ohms instead of 4 ohms like the original. This would reduce the output of the class AB amp. Instead I ordered speaker adhesive and a new surround to repair the original. It now sounds great again. It is a fun project if you are a little handy.To get to one of the speaker screws, you have remove one circuit board and loosen and bend over the other one. The hardest part was removing the 2 small knobs. They were really stuck on. I couple of years ago, I carefully removed the sticky, failed soft touch finish. I painted it with 2 tones of Rustoleum spray paint for plastic with a top coat of Rustoleum clear coat. It look great.
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 26
Ao todo: 2,234
4 comentários
Hi @artvalder ,
Before trying to replace the speaker, have you proved that the speaker is the problem?
If not try the following:
Listen to the audio with headphones. If it is also distorted then it is not the speaker that is the problem. It could be the audio amp.
Listen to the audio using an external audio input connected to the aux input. If not distorted then it is not the speaker. If it is distorted it could be the audio amp.
Apologies if you have already done this, but you didn't say and I'm just covering all bases. ;-)
por jayeff
Good Points! It actually distorts when I have audio connected to the audio in., not on the radio. It can't handle the bass.
por Jay
Would this be the audio amp as well?
por Jay
My speaker is distorting because the flexible surround material is deteriorated and torn. I'm trying to locate a replacement speaker without success. Has anyone located a source for these small PAL speakers?
por Mark
