2016 MacBook hard drive missing
I have a 2016 MacBook that I repaired after a customer stepped on it. The Mac was running fine, and the only damage was a distorted screen along the left-hand side. I successfully replaced the display assembly, BUT . . .
Now, the hard drive has vanished. The computer starts, but it does not see the hard drive. It's as if the hard drive got disconnected. I have tried Internet-based recovery mode by holding down command and r. When it gets to macOS Utilities' Disk Utility, nothing is there. There are no drives/volumes present.
If anyone has had this issue with the 2016 or 2015 Macbook, I suspect the solution is similar. So let's hear your thoughts.
Help please.
Esta é uma boa pergunta?
Chris - I had a motherboard with a crack alongside the CPU.
That machine was squashed in the car seat, and broke the screen
The entire case was perfect,,, not even a scratch.
I'm afraid your job is not done ;>)
por Tom Shafer
Thanks Shafer.
Thing is, it was working until I reassembled after replacing the display. One problem fixed; another created.
Appreciate your time.
C
por Chris Leeds
