Ir para o conteúdo principal
Repair manuals and information for the Microsoft Surface line of tablets.
My charger doesn't charge.
After going down from lack of battery, my tablet won't charge. The charger Light doesn't turn on, and I need some solution that doesn't involve buying a new one or throwing everything against the wall...
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Just tested with a multimeter, and apparently the charger is working...
The problem must be in the battery.
por
Adicionar um comentário
1 resposta
Solução escolhida
@gc05 you could check your charger with a multimeter first to make sure that it is working. If it is then you are possibly having issues with either the charging port Microsoft Surface Charging Port Replacement or the battery. If your battery is depleted or discharged below the charging threshold it will no longer accept a charge. Replace the battery and see if that works. Microsoft Surface Battery Pack Replacement
Imagem de Microsoft Surface RT Battery Pack
Guia
Nível de dificuldade:
Moderado
5 - 10 minutes
Imagem de Microsoft Surface RT Charging Port
Guia
Moderado
15 - 30 minutes
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Gil Cancela será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 35
Ao todo: 25,448
